Cooling Performance
For cases capable of housing ATX or larger motherboards, we use our standard ATX case test kit, which includes:
We disable the motherboard's onboard CPU fan control and all CPU power management features. The CPU fan is fixed at 7V with an adaptor while the graphics card fan is locked at 70 percent speed using MSI Afterburner. The system is loaded using Prime95 25.11 and Unigine's Heaven 4.0 benchmark. We use Core Temp and GPU-Z to monitor the temperatures, taking the maximum values after 15 minutes - enough time for the readings to plateau.
        Lian Li PC-D888 (8 x 120mm fans; max speed)
        In Win 509 (140mm rear fan)
        SilverStone Primera PM01
        Phanteks Enthoo Pro M Tempered Glass
        SilverStone Raven RVX01
        Corsair Crystal Series 570X RGB
        NZXT S340 Elite
        BitFenix Aurora
        Cooler Master MasterCase Pro 5
        Lian Li PC-D888 (8 x 120mm fans; min speed)
        Be Quiet! Dark Base Pro 900 (inverted ATX)
        Corsair Crystal Series 460X RGB
        In Win 303
        Nanoxia Project S
        Corsair Carbide Series 270R
        No case - open test bench
        Corsair Carbide Series 600C (max speed)
        Aerocool DS 230
        Be Quiet! Dark Base Pro 900 (max speed)
        Be Quiet! Silent Base 600 (max speed)
        Corsair Carbide Series 400C
        Corsair Carbide Series 600C (med speed)
        Corsair Carbide Series 600C (min speed)
        In Win 805
        Be Quiet! Dark Base Pro 900 (min speed)
        BitFenix Pandora ATX
        Phanteks Eclipse P400S (max speed)
        Be Quiet! Silent Base 600 (med speed)
        BitFenix Nova
        In Win 509 (stock - no fans)
        Be Quiet! Silent Base 600 (min speed)
        Phanteks Eclipse P400S (med speed)
        Lian Li PC-D888
        Phanteks Eclipse P400S (min speed)
°C (Lower Is Better)
        NZXT S340 Elite
        In Win 303
        Lian Li PC-D888
        BitFenix Aurora
        In Win 805
        Aerocool DS 230
        Nanoxia Project S
        BitFenix Nova
